whitrzac Posted April 26, 2015 Share Posted April 26, 2015 I installed my LC2 today after weeks of putting it off... I can see the LC2 in logworks and romraider if I use a USB/serial adapter. When I plug the 2.5mm serial cable into the openport 2.0. romraider cant seen the lc2. I'm getting mixed messages about the 2.5mm serial jack on the openport 2.0. Can romraider see a wideband on this jack? Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted April 27, 2015 Share Posted April 27, 2015 The OP2 can see the 2.5mm jack when it is standalone logging but you have to plug it into the USB for romraider. IF you have TGV deletes, I'd suggest running the 0-5v output to one of the TGV sensor wires. That way you can log directly from the ECU(pretty cool for AP users also). Link to comment Share on other sites More sharing options...
