billvegaschris Posted April 25, 2015 Share Posted April 25, 2015 1996 Legacy LSI Sparatic drivers side front shaking I had a new tire put on the rear and they moved the old one to the drivers front. I also had all the tires balanced. I still get a sparatic shake on the drivers front. It seems to happen just in first gear and then goes away I want to know what I should check for before I spend money and get an alignemnt if I do not have to Thanks for the help. Link to comment Share on other sites More sharing options...
taylormac1993 Posted April 26, 2015 Share Posted April 26, 2015 Check your cv axles. Also lift the front of the car and check for play in the front wheels. Dont rule out either side until youve found the problem. Link to comment Share on other sites More sharing options...
