n2oiroc Posted January 25, 2017 Share Posted January 25, 2017 brought mine to the dealer for the muffler and they are ordering a new one. there is also a tsb out for something about the muffler shell rigidity. Link to comment Share on other sites More sharing options...
cerbomark Posted January 26, 2017 Share Posted January 26, 2017 TSB # s please. Link to comment Share on other sites More sharing options...
ammcinnis Posted January 26, 2017 Share Posted January 26, 2017 TSB # s please. Search the Subaru Technical Information System web site. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
cerbomark Posted January 26, 2017 Share Posted January 26, 2017 http://techinfo.subaru.com/search/listResults.html Ok, got it. It appears that only some muffler s have that seam on the bottom. Mine is solid at that point. OP er, that seam was on bottom, correct? Link to comment Share on other sites More sharing options...
n2oiroc Posted January 27, 2017 Share Posted January 27, 2017 Ill try and get some more info on the tsb when i bring it in for the new muffler. Link to comment Share on other sites More sharing options...
n2oiroc Posted January 31, 2017 Share Posted January 31, 2017 i didnt get a tsb # or anything but i asked about it. he said they have a new updated muffler out now to address what happened to mine and the op. Link to comment Share on other sites More sharing options...
cerbomark Posted January 31, 2017 Share Posted January 31, 2017 go onto the link I posted, "Online Refs " fill in drop downs and there it is... Link to comment Share on other sites More sharing options...
waldguy Posted February 1, 2017 Share Posted February 1, 2017 For the record: TSB 09-66-16 Rear Muffler Shell Rigidity Enhancement This bulletin announces a change in the production procedure for the rear muffler assembly. Spot-weld locations securing the outer shell portion have been changed to improve overall rigidity. A gap may develop at the spot welded seam as a result of repeated thermal shock (heating / cooling) which occurs during normal use. The gap does not create an exhaust leak. In some cases, a rattling sound from the muffler may develop. Information contained in any technical document found on the STIS web site should only be used as reference material for highly trained automotive technicians. Only automotive technicians have the training and the special tools/equipment to repair Subaru vehicles. Link to comment Share on other sites More sharing options...
