robmat Posted April 19, 2015 Share Posted April 19, 2015 I swapped springs yesterday and have gotten the P0500 code, along with limp mode and the usual (from what I've read) symptoms. I pulled the C codes and got C0104, C0114, and C0115. C0104 Front LH sensor malfunction C0114 Valve Relay on Failure C0115 ABS wheel speed sensor malfunction (ABS wheel speed sensor abnormal signal) Abnormal ABS wheel speed sensor on any one of four sensors Can anyone help shed a little light on the situation? I will replace the front left sensor, but are the other two codes related or a different issue altogether? Feeling a little over my head, so thought I would ask. Thanks so much- Please let me know if I can provide any more info. Robmat Link to comment Share on other sites More sharing options...
TYRKA06GT Posted April 27, 2015 Share Posted April 27, 2015 Man I'm almost positive I have the same thing going on with mine. I went and replaced the front left speed sensor but I don't know about the other 2 chassis codes. Does yours not allow you to go over 4k rpms? Rough idle? Link to comment Share on other sites More sharing options...
robmat Posted April 27, 2015 Author Share Posted April 27, 2015 I had rough idle and the 4k limit. I replaced the speed sensor and everything seems to be good to go now. I haven't rechecked the chassis codes, but am happy with the fix for now. Link to comment Share on other sites More sharing options...
TYRKA06GT Posted April 28, 2015 Share Posted April 28, 2015 I drove with my buddies OBD reader and we tested the ABS system. It showed no output from the front left sensor so I replaced it. Turns out I still have the issue, someone mentioned about the front right controlling the VSS and that's my error code. P0500 Link to comment Share on other sites More sharing options...
robmat Posted April 28, 2015 Author Share Posted April 28, 2015 It could be the right one as well. I inspected both while still on the car and couldn't find a thing. When I removed the passenger side sensor, I found the tiniest of tears near the plug that holds the wire in the wheel well. I would never have seen that without removing it. It was a total headache. Good luck with it! Link to comment Share on other sites More sharing options...
