subarunewb Posted April 18, 2015 Share Posted April 18, 2015 I went out to my car this morning, and my ABS light came on, a d stayed on, what does this mean? my subaru is a 95 legacy l Link to comment Share on other sites More sharing options...
propanejoe Posted April 19, 2015 Share Posted April 19, 2015 Among other things it means yor cruise control wont work now... Mine doest either. Link to comment Share on other sites More sharing options...
twisty Posted April 20, 2015 Share Posted April 20, 2015 probably a wheel sensor. i havent ever tried to read the brake codes with my snapon scanner yet, but mebbe having the codes read would give you some info Link to comment Share on other sites More sharing options...
propanejoe Posted April 20, 2015 Share Posted April 20, 2015 Somewhere on this forum, I cant find it right now,I located a procedure for reading the abs codes via grounding out a terminal in a connecter located under the dash. Mine was found above the gas pedal. the black 6 terminal plug is not connected to anything, and it has a couple of grounding pins taped up to the harness right behing the plug. undo the tape to find the pins. Got this far? OK. Next take one of the ground pins and with locking clip thingamajig on top and the business end of the plug facing you, poke the pin into the socket on the lower right hand corner of the plug(#6) turn the iggy to on (not start) and count the flashing ABS light. Long flashes are the first digit, and short flashes are the second of a 2 digit #. ie; __ __ , _ _ would be 22 for example. Write thes numbers down and search about on here to decipher them. the number sequence ends I think with a 11 ( __ , _ ) I tried it yesterday and am still trying to figure out what is all wrong with mine but at least i am on a path that has a bit of light shining on it now and i'm not stubling around in the dark. Link to comment Share on other sites More sharing options...
subarunewb Posted April 22, 2015 Author Share Posted April 22, 2015 It was my ABS relay.... Only thing I did, was open the relay box, tap on the relay and the abs light went off and the abs pump isn't making the noise that it was making Link to comment Share on other sites More sharing options...
subarunewb Posted April 26, 2015 Author Share Posted April 26, 2015 The light came on again, took it to Firestone, they said something about "Something was stuck inside the master cylinder" ....? They fixed the issue though. Link to comment Share on other sites More sharing options...
