questions on deleting oem nav and can bus
finse
Posted
Currently my 06 Spec B has the original nav setup in place. It's antiquated, and now longer very useful as the car is mostly used at the track now. I'd like to replace the screen with a tablet or a carputer that could be useful on the track. This leads me to my questions.
First, do any of you know of a spot where I can tap can-h and can-l? I'm pretty sure the nav is using can-h and can-l, I just don't know which wire.
Second, are there any ramifications on removing the nav system from the car completely?
Posted
Found my answer on the nav delete; it should be fine to remove. Still looking for information on the can bus wiring, anyone have any knowledge? wiring diagrams?
