RCA to bluetooth receiver with Jazzy AUX
porsche5k
Posted
I ordered the Jazzy Aux input, which has a RCA female outlet. Is it possible to do an RCA to bluetooth receiver? Or does this such thing exist? It would be nice not to have to run the AUX wire in my car!
Posted
I believe you are referring to this : http://www.jazzyengineering.com/product_info.php?products_id=44
If so, you can easily connect a bluetooth headphone adapter .
just found this , should work and you can plug directly into 12volt so piggy back on the 12v outlet if you want!
[ame=http://www.amazon.com/Bluetooth-Boat-Stereo-Receiver-Adaptor-Converter-Receiver-Dongle/dp/B00JAPZRH2/ref=sr_1_2?ie=UTF8&qid=1427987229&sr=8-2&keywords=bluetooth+rca+adapter]Amazon.com : Bluetooth Car, Boat, Spa Stereo Receiver Adaptor-Converter-Receiver-Dongle 12V : Car Electronics[/ame]
Posted
So if I understand this correctly:
Step 1 - Jazzymod radio surgery
Step 2 - Plug in [ame=http://www.amazon.com/Bluetooth-Boat-Stereo-Receiver-Adaptor-Converter-Receiver-Dongle/dp/B00JAPZRH2/]Amazon.com : Bluetooth Car, Boat, Spa Stereo Receiver Adaptor-Converter-Receiver-Dongle 12V : Car Electronics[/ame]
Step 3 - Bluetooth installation complete?
This just might be my ticket to Bluetooth in the 05/06 model years with no aux in jack.
If someone thinks I'm mistaken, please chime in. I'll likely pursue this otherwise.
Posted
The only thing people mentioned in the comments on Amazon is done engine whine coming through. but that depends on where you plug in your 12 volt. Also, if it bothers you, can always add a ground loop isolater circuit.
Otherwise it looks good to me!
