bjkroll Posted March 25, 2015 Share Posted March 25, 2015 So I've had a 2.2 sitting on a stand for about 8 months now, and with the temperature rising.. it needs to go back in my Subaru. I'm running a 2.5 right now, but I know it has issues. Needs the timing done, new head gaskets, etc etc. I loved the 2.2, the only reason its sitting on a stand is because the car was totaled, and I wanted to save the engine / trans (and a few other good components). Anyways, to get to the point, what should I really do to this motor before I put it back in? Since its already out should I bother with new head gaskets? Do they ever go bad on the 2.2? I was thinking of doing the valve cover gasket/seal, cam seal, and oil separator plate. Should I tinker with the rear main seal, or just leave it be if its not leaking? Obviously, I'll be doing the timing belt, all pulleys, and the water pump. Also a new hydraulic tensioner. Am I forgetting anything? Any input is appreciated! Thanks! Link to comment Share on other sites More sharing options...
johnegg Posted March 25, 2015 Share Posted March 25, 2015 what year is it? miles? trans? Link to comment Share on other sites More sharing options...
bjkroll Posted March 26, 2015 Author Share Posted March 26, 2015 1997. Unknown miles. Pulled from a junkyard, who claimed it was a 2.5L, when in fact it was a 2.2. The trans is a 4EAT, rebuilt by Subaru in 2007. Works great. AWD works. No torque bind. Thats going in when I put the 2.2 back in. Link to comment Share on other sites More sharing options...
bjkroll Posted April 10, 2015 Author Share Posted April 10, 2015 Bump? Link to comment Share on other sites More sharing options...
johnegg Posted April 10, 2015 Share Posted April 10, 2015 97 is an interference engine. you should do the following before install: t-belt all idlers idler for the tensioner, not the piston unless damaged water pump cam seals and cam cap o-rings crank seal oil pump o-ring reseal oil pump check screws on the back of the oil pump oil separator plate on the back of the block if not a metal one plugs plug wires valve cover gaskets parts cost for the above about $250. this sounds like a lot but you will be set for 60k trouble free miles. t-belt kit online w/ water pump = $135 shipped, amazon oil seals $30 at dealer online plug wires $40 at dealer online oil sep plate w/ screws $35 at dealer online order all 3 at one time. all oil seals from subaru. plug wires from suabru oil separator plate w/ screws from suabru other parts, oil and coolant from local or online parts store. Link to comment Share on other sites More sharing options...
bjkroll Posted April 10, 2015 Author Share Posted April 10, 2015 Excellent! Thank you very much, sir! Link to comment Share on other sites More sharing options...
