enzo.kz Posted March 20, 2015 Share Posted March 20, 2015 Hi guys! I wanted to replace steering pump on my subie. I have two steering pumps - one is dead one installed on my car (leaking everywhere ) with NO REPAIR KITS (seals rings etc). Pump part number is: 34430-AG011. Second one was ordered abroad, P/N: 34430-AJ020 from Legacy N/A 3.6L EZ36 engine. But when i wanted to installed it, i saw that pulley is bad, you can check the video https://www.youtube.com/watch?v=dKSSqDsAVNg Now i want to remove pulley from my own pump and install it on new pump. My Engine is NA 3.0L EZ30D engine. Car model: 2005 Legacy 3.0 EDM Same type of pumps installed on USDM Outback N/A 3.0L 2005-2009. There is thread inside the steering pump shaft, which you can use for "pulley removing kit", but i am not sure, which of this kits can be used for this type of pulley/pump. My pump's pulley center doesn't have "edge", where pulley removing tool "drags" the pulley. Thanks in advance! Link to comment Share on other sites More sharing options...
travrach Posted March 20, 2015 Share Posted March 20, 2015 My pump's pulley center doesn't have "edge", where pulley removing tool "drags" the pulley. ^I don't understand this part. Are you saying your pulley currently on the car does not look the same as the pulley in the video? Link to comment Share on other sites More sharing options...
enzo.kz Posted March 20, 2015 Author Share Posted March 20, 2015 ^I don't understand this part. Are you saying your pulley currently on the car does not look the same as the pulley in the video? Pulleys are same. I cannot remove\replace damaged pulley (watch video). Rgds Enzo Link to comment Share on other sites More sharing options...
travrach Posted March 20, 2015 Share Posted March 20, 2015 Enzo, I did watch it. Watch and it shows you how to remove it and explains the tools needed. Link to comment Share on other sites More sharing options...
enzo.kz Posted March 20, 2015 Author Share Posted March 20, 2015 Enzo, I did watch it. Watch and it shows you how to remove it and explains the tools needed. If you watch your DIY video, that guy explains that your pulley must have "lips" for grabbing a pulley. Exact time in video 3:06 and 7:20. The problem is that my type of pulley don't have such lips. So nowhere to drag. Link to comment Share on other sites More sharing options...
travrach Posted March 20, 2015 Share Posted March 20, 2015 Got it, sorry when I watched your video it looked like it had a lip, I had to enlarge and then was it was just a color difference. You will need a jaw puller like this- But practice on the bad pulley 1st, as you can break the pulley with this style. Link to comment Share on other sites More sharing options...
enzo.kz Posted March 21, 2015 Author Share Posted March 21, 2015 Got it, sorry when I watched your video it looked like it had a lip, I had to enlarge and then was it was just a color difference. You will need a jaw puller like this- But practice on the bad pulley 1st, as you can break the pulley with this style. I tried to use such tool already - pulley gets damaged when u use force to grab it Link to comment Share on other sites More sharing options...
travrach Posted March 21, 2015 Share Posted March 21, 2015 Then you need to take it to someone who has a press. Link to comment Share on other sites More sharing options...
