Nebraskasubi Posted March 15, 2015 Share Posted March 15, 2015 hi a little background on the car i bought a outback wagon of craigslist for about 350 because the cam gear pulleys blew up so i went to the local u pull it and found a engine and figured id do the manual swap while i was at it mechanically everything bolted up smoothly but now i cant get my fuel pump to prime i spliced the wires together were the auto shifter was so i can remove the key and the engine cranks when i manually try to start it via the starter. i dont have a neutral safety switch ive been trying to bypass any ideas would be great thank you Link to comment Share on other sites More sharing options...
Nebraskasubi Posted March 16, 2015 Author Share Posted March 16, 2015 Bump anyone? I got it cranking just cant figure out why the fuel pump wont prime relay seems to be clicking but no fuel. Link to comment Share on other sites More sharing options...
twisty Posted March 16, 2015 Share Posted March 16, 2015 youd get more response if you posted this in the 2nd gen forum, im not sure how many people from there look at the picture galleries. sorry i dont have a good answer for the issue, but im sure someone in the other area will know. http://legacygt.com/forums/forumdisplay.php/second-generation-legacy-1994-1998-95.html Link to comment Share on other sites More sharing options...
Nebraskasubi Posted March 22, 2015 Author Share Posted March 22, 2015 thank you Link to comment Share on other sites More sharing options...
