rrobe99999 Posted March 7, 2015 Share Posted March 7, 2015 I am looking for some advice on how to fix my car. I believe there is a fuel problem. I got code P0442 twice within a few days. Each time I remove and replace gas cap, reset ECU, and it goes away. Thinking I may need a new gas cap but haven't replaced it yet. Car still ran fine. But today the car would not start. I start troulbeshooting at the fuel pump. I do not hear it working when I turn on the key. I remove the connector at the pump and I've got 10.5V at pins 5 and 6, when I trun the key which should be good. According to FSM, I need a new fuel pump. Then I connect another 12V source to the pump just to make sure, and I can hear it working. Car still won't start though and throws code P0183 for high fuel temp. I figure this is because I have 4 other pins disconnected at the pump for my test set up with extra 12V source. What should I check next? Link to comment Share on other sites More sharing options...
06leg315 Posted March 8, 2015 Share Posted March 8, 2015 That's an Evap code and will not cause the car to not start. Link to comment Share on other sites More sharing options...
