hawkm Posted March 7, 2015 Share Posted March 7, 2015 [/b][/b]I bought a 90 subaru legacy l and it was running on 3 cylinders. I found a fuel injector bad and the guy I got the car from had said that he drove this car this way the whole time he had the car who know how long. I replaced the injector and the car started to knock pretty bad. I've heard a lot of lifters tick before and this does NOT sound like a lifter. More like a connecting rod. Could you give me any ideas on possibilities here? Link to comment Share on other sites More sharing options...
hawkm Posted March 7, 2015 Author Share Posted March 7, 2015 I'm sorry after putting the new injector (junk yard) The motor turned over but then stopped as if it was locked up. I pulled the junk yard injector back out and put the old injector back in. One I turned it over it started and now we have a knock. Did I ruin this thing Link to comment Share on other sites More sharing options...
USLiberty Posted March 7, 2015 Share Posted March 7, 2015 You can use a long screwdriver held up to your ear as a stethoscope. you can almost pinpoint the noise from under the car. Definitely easy to tell if it's the block or the heads. Link to comment Share on other sites More sharing options...
