Steve ko Posted March 4, 2015 Share Posted March 4, 2015 Has anybody rewelded the lower flange on a invida uppipe? I have a crack in the flange weld causing a cel (lean). I have access to a certified welder (I run a metal fab shop) who could tig the crack closed. Also are they mild steel or st.st. I haven't removed it yet. Link to comment Share on other sites More sharing options...
baconbits Posted March 4, 2015 Share Posted March 4, 2015 Stainless. It could be rewelded no problem. Link to comment Share on other sites More sharing options...
doobaruGT Posted March 4, 2015 Share Posted March 4, 2015 It depends on where the crack is. I had the same issue but it was oriented towards the engine. If you pop it off to weld it, like I did, you run the risk of flange misalignment, again, like I did. If the crack is street side, facing down, then I think that's a better option. I pulled it three times to try and correct it before I went with a GS flex unit. Headache over Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
baconbits Posted March 4, 2015 Share Posted March 4, 2015 Depends on the welder's ability to control heat and such. If it's a short crack, sure, patch it. If it's halfway around the pipe, you're definitely going to get some heat distortion. Link to comment Share on other sites More sharing options...
doobaruGT Posted March 4, 2015 Share Posted March 4, 2015 Depends on the welder's ability to control heat and such. If it's a short crack, sure, patch it. If it's halfway around the pipe, you're definitely going to get some heat distortion. Glad this was brought up. I had the same issue and tried to belt sand the flange flat...as I mentioned in my former post, it didn't work out. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
baconbits Posted March 4, 2015 Share Posted March 4, 2015 I have no idea how thick the tubing or flanges are on their uppipes... the thicker, the better, as they won't heat distort as much or at all depending on crack/weld size. Link to comment Share on other sites More sharing options...
doobaruGT Posted March 4, 2015 Share Posted March 4, 2015 I have no idea how thick the tubing or flanges are on their uppipes... the thicker, the better, as they won't heat distort as much or at all depending on crack/weld size. Mine was fairly beefy and it still warped. I would say it was close to the GS flange thickness but that's based on my [declining] memory Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
