nettkonge Posted February 19, 2015 Share Posted February 19, 2015 Hi i am need som help to instal boost gauge.haw to conect the vacuum line and haw to contact to get redigere from both turbos Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 19, 2015 Share Posted February 19, 2015 I don't know what redigere means. Installing the boost gauge is easy. Just pick a vacuum line and install a T fitting and attach your boost gauge vacuum line to that. For power you can tap into a wire such as the cigarette lighter but I like to use an 'Add a fuse' that plugs into the fuse box like this: [ame=http://www.amazon.com/Add-A-Circuit-same-function-Bussmann-Fuse/dp/B007FFG5YI]Amazon.com: ATM Add-A-Circuit (same function as Bussmann BP/HHH), ATM Fuse Tap: Automotive[/ame] Any vacuum line will work, but I just tapped into a vacuum line that was going to my boost control solenoid and zip tied the line through the engine bay. You will need to poke a hole in your rubber firewall plug (you can use a large nail or awl) and shove the vacuum line through that and connect it to the boost gauge sending unit. Common places to put the gauge are on the dash, the steering wheel bezel, in the din pocket below your stereo, etc. Link to comment Share on other sites More sharing options...
nettkonge Posted February 19, 2015 Author Share Posted February 19, 2015 Thanks fore tour help Link to comment Share on other sites More sharing options...
GTEASER Posted February 19, 2015 Share Posted February 19, 2015 You don't need to attach it to both turbos, it just needs to be connected to a small vacuum line going to the intake manifold. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
nettkonge Posted February 20, 2015 Author Share Posted February 20, 2015 Thanks for the riplay Link to comment Share on other sites More sharing options...
