ksuwildcat2010 Posted February 18, 2015 Share Posted February 18, 2015 I have a stock 2009 legacy 2.5i limited and looking at a set of 215/60r17's but not sure if they will fit? I've read where new outbacks and crosstrek's run this size but I don't know if they will fit a legacy. Any help would be appreciated. Link to comment Share on other sites More sharing options...
Rhitter Posted February 18, 2015 Share Posted February 18, 2015 You can use this to check - http://www.willtheyfit.com/ This has answered a lot of questions about fit http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html My OBXT build Link to comment Share on other sites More sharing options...
ksuwildcat2010 Posted February 18, 2015 Author Share Posted February 18, 2015 Damn, doesn't seem like they will fit. Wanted to go a little more off road friendly with some Geolander A/T-S. I didn't figure there would be that much clearance difference between a Legacy and an Outback. Link to comment Share on other sites More sharing options...
boxkita Posted February 18, 2015 Share Posted February 18, 2015 your legacy: http://www.cars101.com/subaru/legacy/legacy2009.html#mechanical is 205/50/17 a comparitive outback (2.5i ltd): http://www.cars101.com/subaru/outback/outback2009.html#mechanicals is 225/55/17 When you got wider, you have to drop the aspect ratio to keep sidewall size relatively the same height. The outback has 1.5 inches more clearance than a legacy. If you really want a more rugged tire, look at fitting a 16inch wheel with a higher profile tire. In theory this will work, as the outback & legacy have same size brake discs. This being the internet, you should verify before spending money. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
