spazlamhaslam Posted February 17, 2015 Share Posted February 17, 2015 I'm trying to lift my LGT a few inches and I'm having some people tell me that 09 and up FXT suspension will do the trick… I don't believe them… Do you? Does anybody know a reasonable way to do this without buying an outback? What is every component I would need? I've searched all over the place and I've seen things that say that it will work and I've seen things that say it won't, is there anyone who really knows what's what? Link to comment Share on other sites More sharing options...
Rhitter Posted February 17, 2015 Share Posted February 17, 2015 Why don't you just use an Outback suspension? My OBXT build Link to comment Share on other sites More sharing options...
spazlamhaslam Posted February 17, 2015 Author Share Posted February 17, 2015 I would do that but I've heard only the outback sedan will work, those are are hard to find. Mostly I'm just trying to get my ducks in a row before I start buying a bunch of stuff. Link to comment Share on other sites More sharing options...
alex0856 Posted February 17, 2015 Share Posted February 17, 2015 I know LGT suspension can fit into an OB, so I don't see why you couldn't go vice-versa. Link to comment Share on other sites More sharing options...
Rhitter Posted February 17, 2015 Share Posted February 17, 2015 Yeah - that's wrong. Any 2005 -2009 Outback suspension will work with your 2006 Legacy. You might need to look into the Outback body lift spacers to adjust with the driveline to compensate for the extra ride height so your cv axles don't explode. My OBXT build Link to comment Share on other sites More sharing options...
Leviman Posted February 17, 2015 Share Posted February 17, 2015 Find someone in your area looking to lower their outback, set the two cars up in a garage and get swappin. My outback is riding on jdm lgt sedan suspension, so it certainly swaps. Link to comment Share on other sites More sharing options...
whitetiger Posted February 17, 2015 Share Posted February 17, 2015 you can just buy new kyb/exel replacement outback struts on tirerack.com. you keep the other mounting hardware and all you need is springs. you can probably use your oem springs so you arent too jacked up. Link to comment Share on other sites More sharing options...
spazlamhaslam Posted February 17, 2015 Author Share Posted February 17, 2015 So just to be clear, outback wagon struts and springs will work with my LGT sedan? And body spacers might be needed also? Link to comment Share on other sites More sharing options...
Rhitter Posted February 18, 2015 Share Posted February 18, 2015 Yes. Read this but backwards http://legacygt.com/forums/showthread.php/lgt-wagon-suspension-swapped-into-outback-xt-140548.html People commonly shove outback springs onto legacy GT struts to get a little bit of height (but less than an Outback) This for the body spacers http://legacygt.com/forums/showthread.php/info-ob-gt-suspension-geometry-removing-spacer-180579.html My OBXT build Link to comment Share on other sites More sharing options...
Leviman Posted February 18, 2015 Share Posted February 18, 2015 Body spacers are used in the outback, so to go full outback you'll need the spacers. However, they won't lift the car at all, only correct geometry. They will also slightly reduce ground clearance. Link to comment Share on other sites More sharing options...
Claw Posted February 19, 2015 Share Posted February 19, 2015 Here's '10 Legacy struts on a 13 Forester: http://www.subaruforester.org/vbulletin/f70/sh-forester-lowered-legacy-takeoffs-125346/ He needed spacers... you should go OBXT suspension instead. I have an extra set of 05 LGT wagon suspension.. I should try fitting them on our 14 FXT this summer. Link to comment Share on other sites More sharing options...
