ryancuddy Posted February 16, 2015 Share Posted February 16, 2015 Hello all, Sorry to begin a new thread if one already exists. I have a 2005 legacy GT and the front headlight went out. Anyhow, I went to pull the connecter plug off my light as usual and it basically crumbled. It was melted and now severed from the wire. I have researched the web and found replacement ceramic connectors, but I have no idea how to rewire it. Is this something that can easily be done at home, or should it be taken to a shop? Also, if there is a DIY post related to this somewhere, please let me know. Thanks! Link to comment Share on other sites More sharing options...
turboboost Posted February 16, 2015 Share Posted February 16, 2015 Got a picture? It'll convey the problem a lot better. As of now, all I can suggest is buying a new connector and soldering the +/- wires or using M/F disconnects to join the OEM harness to the new connector. Link to comment Share on other sites More sharing options...
iNVAR Posted February 16, 2015 Share Posted February 16, 2015 It's self explanatory if you just look a little further along the wire. It's a harness. You unplug the low and high beams and disconnect the harness. Put in the new one, reconnect your bulbs. Done. 5 minute job if it's not freezing cold outside. Link to comment Share on other sites More sharing options...
ryancuddy Posted February 16, 2015 Author Share Posted February 16, 2015 Thank you for the feedback! Much appreciated. Link to comment Share on other sites More sharing options...
travrach Posted February 16, 2015 Share Posted February 16, 2015 OP do you simply have something like this? You don't have a plug & pay harness do you.. Link to comment Share on other sites More sharing options...
iNVAR Posted February 17, 2015 Share Posted February 17, 2015 http://opposedforces.com/parts/legacy/us_b13/type_7/electronic/head_lamp/illustration_1/ Should be 84981AG070 Link to comment Share on other sites More sharing options...
