08obxt Posted February 13, 2015 Share Posted February 13, 2015 I have been doing a ton of research and have decided to lower the outback with stock struts and lgt springs. Should I be buying oem springs or aftermarket lowering springs? Next is I would like to have yellow fogs, how do I accomplish this? Link to comment Share on other sites More sharing options...
Rhitter Posted February 13, 2015 Share Posted February 13, 2015 What made you decide on the stock struts? They aren't very good. Most will recommend a Koni insert or a Bilstein HD set-up. Lowering springs will just have you lower and should be paired with an aftermarket strut. They are not a very good match for the OEM struts. If you just want to go low cheaper - get oem legacy gt struts and springs (used). Because the Outback has bigger tires it will visually appear lower than a Legacy GT. Don't forget Legacy GT bumpstops Laminx Foglight covers or Yellow bulbs. My OBXT build Link to comment Share on other sites More sharing options...
08obxt Posted February 13, 2015 Author Share Posted February 13, 2015 Thanks so much for the info. Link to comment Share on other sites More sharing options...
