Soarin Posted February 7, 2015 Share Posted February 7, 2015 What is the sizing for the rear swaybar on our USDM LGT sedans? I got the 20mm Whiteline ones on and they're too big. The bar clearly has space. I can't afford a new rear swaybar right now (I'd get the AVO one if I could), but I can at least upgrade the bushing. What is a good polyurethane bushing in the right size? Otherwise I'll end up putting the stock ones back on. I need to know asap cause the shop is installing more on this coming Thursday. Link to comment Share on other sites More sharing options...
Soarin Posted February 7, 2015 Author Share Posted February 7, 2015 I did some research and found out it's a 15mm bar. I purchased W0406-15 and I'm waiting for it. It's such a small bar... Why? Link to comment Share on other sites More sharing options...
ras06LGT Posted February 9, 2015 Share Posted February 9, 2015 Now you understand why many people replace the rear sway bar with something larger as one of their first handling improvements. Link to comment Share on other sites More sharing options...
ragman Posted February 11, 2015 Share Posted February 11, 2015 General consensus is that rear LGT sway bar is 16mm on US cars. Link to comment Share on other sites More sharing options...
Soarin Posted February 14, 2015 Author Share Posted February 14, 2015 I got that number too. I'm just gonna go for a bigger rear swaybar in March. Link to comment Share on other sites More sharing options...
