Soarin Posted January 30, 2015 Share Posted January 30, 2015 I know this has been touched in a previous thread, that helped me collect the parts I have. But, I want to double check and make sure I have what's needed to change the rear bushings and make the most difference with being relatively good with price. So far I have the following Whiteline bits: W63394 - control arm, lower rear outer bushing W63396 - control arm, upper inner bushing KCA399 - control arm, upper outer bushing with camber adjustment W63398 - rear trailing arm bushing The only other things going on the back are AVO 70mm rear endlinks and new OEM rear swaybar bushings. Or should I go Whiteline with that too? My LGT has about 95,000 miles on the clock and things look worn, but holding well since this car has only been in southern California and northern Nevada. What else could I need? Link to comment Share on other sites More sharing options...
