MBrennan Posted January 30, 2015 Share Posted January 30, 2015 08 LGT Limited with dual climate control and navigation When I change the air output location, air will go to the directed vent location but i still have air flow coming out of the defrost. Link to comment Share on other sites More sharing options...
GregP Posted January 30, 2015 Share Posted January 30, 2015 I seem to be having a similar issue with my 06 with dual climate control. With the heat only supposed to be coming on the floor, it seems really noisy, and air is coming out the defrost and side ducts, with only limited amount out of the floor. I'm just logging in now to see if there's any topics relating to that issue. Hope I find something Link to comment Share on other sites More sharing options...
MrTris Posted January 30, 2015 Share Posted January 30, 2015 I think that's common on all LGT and Subarus. Never had a Subaru that didn't vent out the defrost as well as the direction I chose on the panel. Link to comment Share on other sites More sharing options...
GregP Posted January 30, 2015 Share Posted January 30, 2015 This is different than how it used to be. Very little floor air flow. Link to comment Share on other sites More sharing options...
ras06LGT Posted January 30, 2015 Share Posted January 30, 2015 I seem to be having a similar issue with my 06 with dual climate control. With the heat only supposed to be coming on the floor, it seems really noisy, and air is coming out the defrost and side ducts, with only limited amount out of the floor. I'm just logging in now to see if there's any topics relating to that issue. Hope I find something If you read the owners manual, you will see that by design the air is supposed to come out the side ducts when you have floor only selected. Link to comment Share on other sites More sharing options...
GregP Posted January 31, 2015 Share Posted January 31, 2015 Yeah, I've seen that, and it always has been like that, I've had the car since new. This is different though, there's almost no air coming from the floor ducts. Actually, after I posted this, I checked further. There is no difference between (floor and defrost) and (floor alone) settings on the controls. There is a problem somewhere. This is my first winter in a particularily cold area, and I'm finding out where my car's weak areas are. Link to comment Share on other sites More sharing options...
R15 Posted January 31, 2015 Share Posted January 31, 2015 Sounds like you have a problem with the selector. I haven't messed with them on these cars but I've had two cars that had this issue and most of the dash had to be taken apart since a tiny clip broke on the end of the selector rod; a New Yorker with "auto" controls and one a Corsica with manual. I'd check the Vacation pics, you might be able to weasel in these from removing the whole double-din unit like if you were going to swap head units? I'm only guessing though as I have the manual controls (which all Legacys should have IMO) and there's tons of room in the dash with the HU out. Link to comment Share on other sites More sharing options...
