Heticor Posted January 29, 2015 Share Posted January 29, 2015 the front tires was an uneven wearing. Inside edge right (passenger) and outside edge of the left side (driver) are wore. the rest of the tire is fine. I took to the dealer , the check the alignment, and according to them is ok and the suspension parts are ok. here is the alignment number: Left Front Camber -0.1 deg Caster 6.2 deg. Toe: -0.01 deg Right Front Camber -0.6 deg Caster 6.0 deg. Toe: -0.01 deg Total toe -0.02 deg Thrust angel: 0.00 deg Left Read Camber -0.9 deg Toe: -0.01 deg Right Rear Camber -1.3 deg Toe: +0.03 deg Total toe 0.02 deg Thrust angle :-0.02 deg Do you see anything that could cause the uneven tire wear? Link to comment Share on other sites More sharing options...
rapture Posted January 29, 2015 Share Posted January 29, 2015 Maybe uneven inflation/ over inflation? Link to comment Share on other sites More sharing options...
ras06LGT Posted January 29, 2015 Share Posted January 29, 2015 You've got 0.5 degree camber difference between the left and right side in the front, which is pretty significant (even though both sides are technically "in spec"). You want them to be even side-to-side as much as possible. Link to comment Share on other sites More sharing options...
Heticor Posted February 2, 2015 Author Share Posted February 2, 2015 what should be the camber difference between the two sides? Link to comment Share on other sites More sharing options...
Jimblaz Posted February 3, 2015 Share Posted February 3, 2015 0 and typically you want 0 toe as well Link to comment Share on other sites More sharing options...
ras06LGT Posted February 3, 2015 Share Posted February 3, 2015 ^^^ Right. Usually, being even side-to-side is more important than the actual number (as long as it's in spec). Link to comment Share on other sites More sharing options...
