Zerohour Posted January 28, 2015 Share Posted January 28, 2015 So had front right caliper fail at 222k. Replaced with reman, failed after 500 miles. Replaced with replacement reman. Has started leaking again. Keeps failing at the seal around piston. Any ideas??? This is an EJ22E without ABS, 57mm single piston caliper. Remans came with new sliders, and sliders are greased. Brakes normally, no excessive vibration or noise. Rotors and pads have approximately 3k on them. Link to comment Share on other sites More sharing options...
ras06LGT Posted January 29, 2015 Share Posted January 29, 2015 Never bought a reman caliper, but do they come with pistons and seals pre-installed, or do you swap over the parts from your old caliper? Link to comment Share on other sites More sharing options...
hybridandy Posted January 29, 2015 Share Posted January 29, 2015 I replaced both front calipers on my car over the summer and I haven't had any problems. The front passenger side had a sticking piston that was wearing the pads unevenly and I just replaced both along with the caliper bracket (so new slide pins). I got one from Advanced Auto and the other from Napa (neither had both) and I've put about 5k miles without any issues. I would suggest trying to get a refund and try another vendor? Link to comment Share on other sites More sharing options...
Zerohour Posted January 30, 2015 Author Share Posted January 30, 2015 Reman calipers are pre-assembled with new seal, piston, and boot. Comes with a reman bracket and new sliding pins/bushing/boots. I rebuilt the first reman caliper last night and installed. The seal on the rebuild kit was "beefier" and I'm starting to suspect the remans have been sitting in a warehouse for several years. This has left the seal compressed and causing pre-mature failure. I'll see if the rebuilt, reman holds up. Just a side note, reman kit was purchased from RockAuto.com. Link to comment Share on other sites More sharing options...
Zerohour Posted February 16, 2015 Author Share Posted February 16, 2015 Trying to catch up on some of my open/semi-active threads: Since I always seem to find old threads with no follow up or answers, just wanted to do a quick update. Brake caliper has been fine since the rebuild. I hope i'm not jinxing my luck, but no issues so far! Link to comment Share on other sites More sharing options...
06leg315 Posted February 16, 2015 Share Posted February 16, 2015 I would check the caliper on the other side see if its frozen. Possible that thus caliper is over working and blowing the seal or whatever. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 22, 2015 Share Posted February 22, 2015 Non OEM made in china by the lowest possible bidder parts are hit or miss. I'd rather pay more for the OEM parts Link to comment Share on other sites More sharing options...
Zerohour Posted February 23, 2015 Author Share Posted February 23, 2015 I rebuilt the first reman caliper last night and installed. The seal on the rebuild kit was "beefier" and I'm starting to suspect the remans have been sitting in a warehouse for several years. This has left the seal compressed and causing pre-mature failure. Not to be smart with Yeu, but you're knocking Asian quality on an Asian built vehicles. Go find a bow-tie forum to make such comments. Based off my tear down I fully suspect the reman parts, which is an OEM Subaru caliper, to have old seals. I attribute this to age of the second gen Legacy and Advance Auto's inventory practices. As the cars are 20 years old, it is feasible that the reman has been in a parts warehouse for a decade! The rebuilt reman is still holding together as of this post. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 23, 2015 Share Posted February 23, 2015 I have yet to replace any OEM calipers on any of my cars... however, when working on other cars, I have replaced many calipers with non OEM parts per owner request and have had to replace the replaced parts on several occasions. Typical POF for OEM has been in excess of 170k and in most instances failure was caused by improper brake change where someone didn't properly lubricate the guide pins and they literally welded themselves to the bracket. Case in point regarding reman vs oem Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 23, 2015 Share Posted February 23, 2015 Never bought a reman caliper, but do they come with pistons and seals pre-installed, or do you swap over the parts from your old caliper? they can be caliper only or completely loaded with bracket, pads, shims, and lube Link to comment Share on other sites More sharing options...
