LegacyCamper Posted January 24, 2015 Share Posted January 24, 2015 I cant find the guide on here for the rear bumper removal, could someone please show me the thread? 96 Wagon 250t Got a nice dent in the plastic now so plan to heat it up and push it out. Thanks Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 24, 2015 Share Posted January 24, 2015 Pretty straightforward to remove. A bunch of screws that hold the skin on, lol. Check the stickies for the fsm. It has a diagram of all the components. If you have trouble finding the link let me know. It's easiest to use the access holes and remove the entire assembly, bumper beam and all. Link to comment Share on other sites More sharing options...
LegacyCamper Posted January 24, 2015 Author Share Posted January 24, 2015 yeah i did do a sticky look through but couldnt find it, so much info in there it gets hard without meta data etc. could you point me to it? Im sure i could figure it out with a diagram. silly question whats a bumper beam? Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 24, 2015 Share Posted January 24, 2015 The bumper beam is the metal support that bolts to the frame and holds then plastic skin that you see on the outside. Here is a diagram from opposedforces.com:http://i301.photobucket.com/albums/nn41/henry616/Mobile%20Uploads/D417E4D4-8724-4A64-8114-866D9444889E_zpstef1eqbp.png Hope this helps. Link to comment Share on other sites More sharing options...
LegacyCamper Posted January 24, 2015 Author Share Posted January 24, 2015 i found the diagram under the stickies. dont want to be snapping any clips. do I really need a torque wrench for this job? Dont have one. eeeek Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 24, 2015 Share Posted January 24, 2015 No, no torque wrench needed, just snug up the four big bolts that hold the beam to the unibody. You will snap some clips but don't worry you can break a bunch and still hold the outer covering. And they are only a buck or two each from the dealer so don't sweat it. The hardest part are the side bolts (number 12/14 & 16 in the diagram I posted). They are a bit tricky to get at and strip but won't hurt anything if you mess them up. Link to comment Share on other sites More sharing options...
LegacyCamper Posted January 24, 2015 Author Share Posted January 24, 2015 thanks for that. whats the benefit of taking the whole bumper beam off? Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 24, 2015 Share Posted January 24, 2015 My bad! You don't need to take the whole bumper and be off if you are just repairing the covering. I had to take the whole assembly off my wagon when I pulled the frame straight after a collision. Sorry about that! I must be too excited about the wrx with a blown motor I just bought and can't concentrate, ha ha. Link to comment Share on other sites More sharing options...
LegacyCamper Posted January 25, 2015 Author Share Posted January 25, 2015 the problem im finding is where all the bolts and clips are located. i presume some were in the boot under the plastic? the ones under are obvious. i thought i saw an online service manual 6 months back but cant find it now. Link to comment Share on other sites More sharing options...
twisty Posted January 29, 2015 Share Posted January 29, 2015 http://legacygt.com/forums/showthread.php/second-gen-factory-service-manuals-literature-186552.html its the last sticky in the list at the top of the page. Link to comment Share on other sites More sharing options...
LegacyCamper Posted January 31, 2015 Author Share Posted January 31, 2015 thats just another parts diagram isnt it? I could only see 3 bolts on the diagram the 3 on the bottom. thanks though. hopefully its self explanatory when i go to do it. Link to comment Share on other sites More sharing options...
twisty Posted February 5, 2015 Share Posted February 5, 2015 http://legacygt.com/forums/showthread.php/second-gen-factory-service-manuals-literature-186552.html its the last sticky in the list at the top of the page. thats just another parts diagram isnt it? . my link is to the sticky with the actual service manuals, not just parts list Link to comment Share on other sites More sharing options...
LegacyCamper Posted February 19, 2015 Author Share Posted February 19, 2015 My bad I didnt see the links haha. Thank you :-) Link to comment Share on other sites More sharing options...
