Jh20067 Posted January 22, 2015 Share Posted January 22, 2015 I have a 97 legacy with the 2.2. Idles very rough and shows a cylinder #1 misfire. Seems to run fine other than that, no hesitations or loss of power. I've swapped plugs and wires and the code stays on #1. New fuel injector also. Any ideas or help? Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 23, 2015 Share Posted January 23, 2015 Have you checked the resistance on the primary and secondary coils of the coil pack? Did you use dielectric grease on the connections? Cleaning your idle air control valve wouldn't hurt. Link to comment Share on other sites More sharing options...
