ClickJacker Posted January 21, 2015 Share Posted January 21, 2015 After having my filler neck replaced a few weeks I got the P1133 CEL. everything I find on the code points to failing front O2 sensor. Has anyone else had this code? Is there anything I should check/try before replacing it? what brand should I go with and where is the best place to get one? Link to comment Share on other sites More sharing options...
johnegg Posted January 21, 2015 Share Posted January 21, 2015 P1133 this is a really unusual and rare code for a subaru. so much so i question if it is correct. read it again. Link to comment Share on other sites More sharing options...
ClickJacker Posted January 21, 2015 Author Share Posted January 21, 2015 Had it re-read at a different location same code came up. Link to comment Share on other sites More sharing options...
johnegg Posted January 22, 2015 Share Posted January 22, 2015 http://www.subaruoutback.org/forums/66-problems-maintenance/14655-fault-code-po1133.html Link to comment Share on other sites More sharing options...
lancerswimmer89 Posted January 23, 2015 Share Posted January 23, 2015 Make sure you're using legit OEM spec sensors, I used an ebay sensor once, and all I got was problems out of it. Its worth the money in the long run, trust me. Link to comment Share on other sites More sharing options...
ClickJacker Posted February 14, 2015 Author Share Posted February 14, 2015 Replaced my front O2 sensor today using a genuine Subaru part and the code is gone!!!!! Link to comment Share on other sites More sharing options...
