olivierdb Posted January 20, 2015 Share Posted January 20, 2015 Car : 2006 Subaru Legacy Wagon Auto it all started with cruising on the highway with the cruise on 100Km/h then suddendly feel the car jerk a little i notice the speedo jumping to 105km/h for a sec then go 100km/h it did this 5-6 time then decide to turn off the cruise. the speedo still jump off 5km/h over the speed im driving at. 2 days later i start the car and a CEL P0500 came on then i delete the code and it stay off drove 200km (120mille) with some jerking when using cruise control 4-5 time so i turn the cuise off but no light came on.2 day's later i drove set the cruise it started jerking the CEL (p0500) ABS flashing cruise ER SS came on turn back home pull the code CEL P0500 and found code 43 ABS/VDC failure.now that i clear all the code all the cel abs er ss are all off.early december i got the front left wheel hub change (SKF BR930473) 2 front rotor+pad and the rear 2 rotor+pad the front left side was really stuck with rust the mecanic used the torch to pull out the caliper and the wheel hub.when changing my oil i notice the lower left grounds is gone. sorry for the long explanation my question is does my VSS is slowly dying on me or missing grounds? or bad abs wheel sensor?! thank Link to comment Share on other sites More sharing options...
travrach Posted January 20, 2015 Share Posted January 20, 2015 More then likely its because of the wheel bearing change, some have had issues like this with certain bearings on these cars. Some info here- http://legacygt.com/forums/showthread.php/success-non-oem-wheel-hub-bearing-units-221269.html?t=221269&highlight=cruise http://legacygt.com/forums/showthread.php/wheel-bearings-oem-after-marketi-222105.html?t=222105&highlight=cruise Link to comment Share on other sites More sharing options...
olivierdb Posted January 20, 2015 Author Share Posted January 20, 2015 for a month i got no problem no CEL Or ABS light does it still mean the wheel bearing is not compatible? Link to comment Share on other sites More sharing options...
Merc6 Posted January 21, 2015 Share Posted January 21, 2015 Did you use cruise control before? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
olivierdb Posted January 21, 2015 Author Share Posted January 21, 2015 when im on the highway always. before and after the change of the wheel bearing hub the cruise work well the problem just started.the hub was change early december. Link to comment Share on other sites More sharing options...
olivierdb Posted January 21, 2015 Author Share Posted January 21, 2015 just found the chassis error code c0104 c0106 Link to comment Share on other sites More sharing options...
