RyanFromSC Posted January 19, 2015 Share Posted January 19, 2015 I'm gathering items for a major tune up on the Suby but rockauto is confusing me... They have a million different choices ranging from $8-$38. Which ones are the "correct" wires? Link to comment Share on other sites More sharing options...
johnegg Posted January 19, 2015 Share Posted January 19, 2015 the ej22 engine is not as picky as the ej25 engine, but they still like quality plug wires. generally, cheap wires will give you headaches. i recommend NGK plugs , (~$2.20 ea.) and suabru wires or NGK wires. i have only used subaru wires, about $40 from an online dealer. no head aches , no worries, ever. some parts need to be from suabru plug wires front o2 sensor cam and crank seals oil pump o-ring water pump gasket oil separator plate on the rear of the block head gaskets some think intake gaskets that's all i can think of right now. Link to comment Share on other sites More sharing options...
RyanFromSC Posted January 20, 2015 Author Share Posted January 20, 2015 Thank you John! Just what I needed to know. Link to comment Share on other sites More sharing options...
