ebayollis Posted January 17, 2015 Share Posted January 17, 2015 I have an 07 Subaru legacy outback sport with 115,xxx miles and when the car is cold it dies when I stop the car with it in drive(automatic) until the car warms up...its like it sputters and jerks then dies...it will immediately start back up with no problems. When you stop the car, if you put it in neutral as you're stopping it will not die...as I stated early once the car is warm it stops dying...when it does this there are no CEL or any other indicators as to the problem...it is a non turbo car Link to comment Share on other sites More sharing options...
AF_3C2 Posted January 17, 2015 Share Posted January 17, 2015 Check your vacuum lines- you have a leak- or maybe a bad sensor (MAF) Link to comment Share on other sites More sharing options...
