mkee87 Posted January 13, 2015 Share Posted January 13, 2015 Does anyone know the part number for the bolt that holds the knock sensor? Link to comment Share on other sites More sharing options...
CloudSeed777 Posted January 13, 2015 Share Posted January 13, 2015 Does anyone know the part number for the bolt that holds the knock sensor? I don't have a part number, I looked but couldn't find it. However, if you can't find it and still have the old bolt take it to Ace Hardware and I can almost guarantee you can find a match. I did the same with Up-pipe studs, and exhaust bolts and they had both. Link to comment Share on other sites More sharing options...
MrTris Posted January 13, 2015 Share Posted January 13, 2015 Knock sensor bolt should be like all the others -- M6x1.25, no more than like, 40mm in length. Link to comment Share on other sites More sharing options...
mkee87 Posted January 23, 2015 Author Share Posted January 23, 2015 Finally got the sucker out of there, it was a m8x1.25 30mm Link to comment Share on other sites More sharing options...
MrTris Posted January 23, 2015 Share Posted January 23, 2015 Finally got the sucker out of there, it was a m8x1.25 30mm So a 12mm head on it? Link to comment Share on other sites More sharing options...
