volleykid Posted September 14, 2005 Share Posted September 14, 2005 how do i set the valve timing and Ignition timing on a 1993 Subaru 108 GL Legacy. hope you guys understand what i am asking as i am relaying a message from the mechanic who is not able to post the question himself. thanks alot for the help volleykid Link to comment Share on other sites More sharing options...
Xenonk Posted September 14, 2005 Share Posted September 14, 2005 valve timing (duration I assume is what you are asking) is based on the cam sprocket.. ignition timing is something else that I am not sure how to set on an older pre OBD-II set up. Keefe Link to comment Share on other sites More sharing options...
volleykid Posted September 15, 2005 Author Share Posted September 15, 2005 I will speak with the mechanic and get back to you later. Thanks for the info. Volleykid Link to comment Share on other sites More sharing options...
