T_Altland27 Posted January 10, 2015 Share Posted January 10, 2015 Found a deal on clist here local not sure if I should go for it or not he said I can have it all for $350 but I'll need a hub adapter and lug nuts since I need new tires anyways. http:// http://chambersburg.craigslist.org/pts/4781984878.html Link to comment Share on other sites More sharing options...
T_Altland27 Posted January 10, 2015 Author Share Posted January 10, 2015 He only has 3 of the adapters or spacer so my other question is do I need the adapter/ spacer? If so where can I get them at? Or just the one to match the other 3 Link to comment Share on other sites More sharing options...
T_Altland27 Posted January 10, 2015 Author Share Posted January 10, 2015 Anyone?? Link to comment Share on other sites More sharing options...
apexi Posted January 10, 2015 Share Posted January 10, 2015 The initial link didn't work for me, so here's a clickable link for anyone else who views the thread. http://chambersburg.craigslist.org/pts/4781984878.html By adapter, I think you might be referring to hub centric rings, since I can see them installed in two pictures of the wheels. In order to get new hub centric rings, you need to know the outside diameter of the existing hub centric rings (or centerbore of the aftermarket wheel), and the inside diameter of the hub centric rings. After searching, a lot of people are saying the hub size on our cars is 56.1 mm. So if that is correct, you'll need hub centric rings with an inside diameter of 56.1mm, but I don't know what the bore on those wheels is. As far as whether or not they are needed.. I would highly, highly recommend using them, especially since you can get a set of 4 for around $10-$15. They ensure that the wheel sits perfectly centered on the hub when you put the wheel on the car. Diagram and a couple pictures http://www.justforwheels.com/hub-centric-rings.jsp Link to comment Share on other sites More sharing options...
T_Altland27 Posted January 10, 2015 Author Share Posted January 10, 2015 The aftermarket rims are 72.6 mm thanks for posting the link to it since the other one didn't work. For $350 you think it would be a reasonable deal thats the lowest he would go and I'm thinking by next winter I'd have to put new tires on it with it only having 7/32's tread now Link to comment Share on other sites More sharing options...
hal9e3 Posted January 11, 2015 Share Posted January 11, 2015 Skinny tires, low offset. Tire Rack recommends the stock size for even for winters but they're notoriously conservative when it comes to fitment. The low offset MIGHT be OK with the skinny tires but again, Tire Rack sells wheels with 45mm offset and says fender rolling may be needed. Link to comment Share on other sites More sharing options...
T_Altland27 Posted January 11, 2015 Author Share Posted January 11, 2015 Ok I've decided that I'm not going to go with that deal I'm just going to wait for something better like black rims like I originally want or maybe just keep my stock rims and just get new tires for now Link to comment Share on other sites More sharing options...
rchayes21 Posted January 13, 2015 Share Posted January 13, 2015 Ya sorry man. I couldn't view the link Link to comment Share on other sites More sharing options...
