Legacy05 Posted September 14, 2005 Share Posted September 14, 2005 So yesterday I started the task of installing the Omori 52mm mechanical boost gauge. The AVO gauge pod was just waiting to be filled. The issue I am having is with the boost gauge line itself. If I were to follow AVO's install guide, the line isn't long enough at all. I am running the line through the drivers side grommet through the fendor well and the tube comes up by the battery. I might be able to get it to fit to the stock BOV. My question, is there a place where I can buy a longer line? Thanks! Link to comment Share on other sites More sharing options...
NutBucket Posted September 14, 2005 Share Posted September 14, 2005 Home Depot has plenty of plastic tubing. Either that or your local parts store has bulk vacuum line as well. Link to comment Share on other sites More sharing options...
Legacy05 Posted September 14, 2005 Author Share Posted September 14, 2005 Sweet .. thanks I will stop by today and pick some up. Thanks for the direction! Link to comment Share on other sites More sharing options...
eldiablo Posted September 14, 2005 Share Posted September 14, 2005 Home Depot has plenty of plastic tubing. Either that or your local parts store has bulk vacuum line as well. Just a thought since I just finished my install - The diameter of the vacuum tubing you purchase at the parts store may not be the same as the one supplied with your gauge so you may need a universal "T" to make it all fit together properly. Good luck. My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
Legacy05 Posted September 14, 2005 Author Share Posted September 14, 2005 Thanks I will keep that in mind ... Link to comment Share on other sites More sharing options...
