The Korean Posted January 3, 2015 Share Posted January 3, 2015 Anyone ever experienced an all cylinder misfire while driving? This happened a couple weeks ago. I'm thinking bad gas as I found out the station I went to uses low quality fuel, but what do you all think? Car is running fine for the most part, except for when I'm coming to a stop and turning the wheel at the same time. Mainly I notice it when I'm attempting to reverse. I suppose it could be the throwout bearing/clutch, but just curious on some comments or if anyone has had this happen to them. Back Story: I was driving home on the freeway and downshifted for a curved freeway interchange. Got on it out of the curve and all of a sudden check engine light started blinking for 30isk seconds then shut off. Ran the codes and this is what popped up... http://i475.photobucket.com/albums/rr120/Jonthekorean/Screenshot_2014-12-17-15-21-44_zpsc9147bc1.png Got home and checked a few gauge values out... Short and Long Term Fuel Trim seem to be fine, so I honestly have no clue... http://i475.photobucket.com/albums/rr120/Jonthekorean/Screenshot_2014-12-17-17-16-02_zps961c83dd.png Link to comment Share on other sites More sharing options...
Gex Posted January 3, 2015 Share Posted January 3, 2015 Sounds like you blew a vacuum line off your blue tee connector under the top mount intercooler. Link to comment Share on other sites More sharing options...
The Korean Posted January 4, 2015 Author Share Posted January 4, 2015 I'm assuming only way to get t this is remove the intercooler? Link to comment Share on other sites More sharing options...
