Spec. B Posted December 30, 2014 Share Posted December 30, 2014 http://legacygt.com/forums/showthread.php/help-brakes-not-functioning-correctly-after-upgrade-235404.html?p=5022831#post5022831[url=http://legacygt.com/forums/showthread.php/help-brakes-not-functioning-correctly-after-upgrade-235404.html?p=5022831#post5022831][/url] Link to comment Share on other sites More sharing options...
Spec. B Posted January 2, 2015 Author Share Posted January 2, 2015 No help guys? Link to comment Share on other sites More sharing options...
Gex Posted January 2, 2015 Share Posted January 2, 2015 I think you ran the master cylinder dry. That or you have a stuck piston which is not uncommon. I'd continue to try and bleed the system and then look at the non functioning piston. If found rebuild caliper and try again. Link to comment Share on other sites More sharing options...
Spec. B Posted January 2, 2015 Author Share Posted January 2, 2015 Master has never been dry so that is not the issue. also, I took the brake caliper off and it is functioning just fine using air with low pressure. while off I inspected it and saw no flaws. Link to comment Share on other sites More sharing options...
meier motor sports Posted January 2, 2015 Share Posted January 2, 2015 skip the mighty vac and bleed the brakes manually. make sure to re fill the master cyl at each new wheel Link to comment Share on other sites More sharing options...
