TakmaN Posted December 30, 2014 Share Posted December 30, 2014 My rotors are warped and will be replacing all 4 and pads. I bought my 2008 LGT with Brembo's from what I believe is an STI swapped on. Can I replace the current rotors with Centric Premiums for a stock 2008 LGT brake setup? Or is there a special rotor I'll need for the BBK? Hope it's not too much of a noob question as this will be my first full rotor and brake pad replacement. Link to comment Share on other sites More sharing options...
Gex Posted December 30, 2014 Share Posted December 30, 2014 Hi there. So first of all the fronts... You will need 04 STI Rotors. The STI rotors are larger then the LGT rotors and also 5x100 bolt pattern. Do you have the rears swapped as well? If so it all depends on how your car was set up to adjust for the smaller LGT parking brake shoe. If you have the larger STI ebrake shoes (160mm for LGT 190mm for STI) then you should be fine to use 04 STI Rotors. If you have DBA Conversion rotors which use a LGT brake shoe surface and do no replace the shoes, then you need to either buy the modified shoes or a replacement sent of rotors. Link to comment Share on other sites More sharing options...
TakmaN Posted December 30, 2014 Author Share Posted December 30, 2014 Thanks! Is there a way I could measure/tell which ebrake shoes I have? Link to comment Share on other sites More sharing options...
Gex Posted December 30, 2014 Share Posted December 30, 2014 Measure the inner diameter of your current rotors. If they are 160 then you have DBA Conversions if 190 then you have the modified ebrake shoes... Link to comment Share on other sites More sharing options...
TakmaN Posted December 30, 2014 Author Share Posted December 30, 2014 Measure the inner diameter of your current rotors. If they are 160 then you have DBA Conversions if 190 then you have the modified ebrake shoes... Sounds simple enough, appreciate the help. I'll be switching out wheels so can do this at the same time. Brakes is one area I'm clueless about as I've never had a car long enough to change them. Link to comment Share on other sites More sharing options...
WRX USA Posted December 31, 2014 Share Posted December 31, 2014 You also need to make sure that your new set of wheels have clearance for the Brembos. Link to comment Share on other sites More sharing options...
TakmaN Posted December 31, 2014 Author Share Posted December 31, 2014 You also need to make sure that your new set of wheels have clearance for the Brembos. Yup, already test fit them and all is clear! The wheels are wider with quite a bit lower offset. There is actually quite a bit clearance, more than I was expecting. Link to comment Share on other sites More sharing options...
TakmaN Posted January 5, 2015 Author Share Posted January 5, 2015 So I just measured the inner diameter of my rotors and they're 8 inches or about 200mm. I'm assuming I have the 190mm e-brake shoes from the STI? Link to comment Share on other sites More sharing options...
kred Posted January 11, 2015 Share Posted January 11, 2015 So I just measured the inner diameter of my rotors and they're 8 inches or about 200mm. I'm assuming I have the 190mm e-brake shoes from the STI? Correct. I need e-brake shoes for my swap too. Now does anyone know where the least expensive place to buy rear e-brake shoes would be? Cheapest I found was $200 + shipping. Link to comment Share on other sites More sharing options...
TakmaN Posted January 12, 2015 Author Share Posted January 12, 2015 To add confusion, I found rotors that look like they're for 190mm e-brake shoes but they actually fit 170mm. Link to comment Share on other sites More sharing options...
kred Posted January 12, 2015 Share Posted January 12, 2015 Seriously?? So what you're telling me is that 200mm inner diameter rotors correspond to 190mm e-brake shoes and 190mm rotors correspond to 170mm e-brake shoes? Link to comment Share on other sites More sharing options...
TakmaN Posted January 13, 2015 Author Share Posted January 13, 2015 Seriously?? So what you're telling me is that 200mm inner diameter rotors correspond to 190mm e-brake shoes and 190mm rotors correspond to 170mm e-brake shoes? Sorry I was not awake when I posted that. It seems like I can't just measure the inner hub to find out what size e-brake shoes I have since that part is the same diameter (202mm) for both the rear rotors for the 190mm and 170mm e-brake shoes. Anyone know a way to check what size e-brake shoes I have without taking off the rotor? http://jamalb.net/pictures/brakespecs/dba_655_cat.jpg http://jamalb.net/pictures/brakespecs/dba_2657_cat_a.jpg Link to comment Share on other sites More sharing options...
