11legacy1657615895 Posted December 29, 2014 Share Posted December 29, 2014 Fellas, Anyone know if the black valance under the bumper adds any aerodynamics? Mine is off a little on one side and I hear it if I go over a speed bump. I'd like to just remove it and install the lip piece. Anyone have a part number for that lip for the front bumper? Thanks as always. Josh Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 29, 2014 Share Posted December 29, 2014 Yes they are aerodynamic in function, just get some new clips and put it back up. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
11legacy1657615895 Posted December 29, 2014 Author Share Posted December 29, 2014 Yeah figured that was the case. Thanks. Any idea on if it is easily had online in case it's too damaged? Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 29, 2014 Share Posted December 29, 2014 you might be able to order it from Subaru Parts Warehouse online but I suspect shipping might be killer on that. The part is functional as it is part of under body smoothing and for airflow management under the hood. Will you likely see any ill effects from removing it? Not too likely, but you may see a drop in MPG and your car may run hotter in the summer, but you'd likely never see the temp difference on your dash because it'd still be in the range that is considered 'normal.' 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
