atfarris Posted December 25, 2014 Share Posted December 25, 2014 my car has been getting harder and harder to start, as its gotten colder. my fans come on after just turning the key forward. They come on for about 2 seconds, shut off for 2 seconds, come back on and just keep doing it. The fuel pump also turns on and off with them. When it finally starts, it runs rough, and bogs down when i hit the gas. Once it starts to get warm, it runs just fine. I tested the cts, based on the diagram I had, it tested fine. I'm not sure where to go from here. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 25, 2014 Share Posted December 25, 2014 hook a data reader to the car and see what it thinks the coolant temp is.... Link to comment Share on other sites More sharing options...
johnegg Posted December 25, 2014 Share Posted December 25, 2014 my fans come on after just turning the key forward. They come on for about 2 seconds, shut off for 2 seconds, come back on and just keep doing it. first check under the dash, are the Green Test connectors plugged in to each other? if yes, dis-connect them. my car has been getting harder and harder to start, as its gotten colder. When it finally starts, it runs rough, and bogs down when i hit the gas. Once it starts to get warm, it runs just fine. check the timing. this is the most common cause of no start issues. check the timing. Link to comment Share on other sites More sharing options...
atfarris Posted December 28, 2014 Author Share Posted December 28, 2014 first check under the dash, are the Green Test connectors plugged in to each other? if yes, dis-connect them. Awesome, it worked. Thank you so much. I don't even remember plugging that in. But it starts first crank now. Link to comment Share on other sites More sharing options...
atfarris Posted January 28, 2015 Author Share Posted January 28, 2015 Well it went back to hard starting. Someone has installed a switch, to turn the fans on all the time. At first it worked fine. One position, the fans came on when they needed. The other position, they stay on. After I un hooked the green connectors, the switch worked again. But now it does nothing, and fans stay on all the time. It looks like it's tied into the cts. Any thoughts? Link to comment Share on other sites More sharing options...
johnegg Posted January 28, 2015 Share Posted January 28, 2015 It looks like it's tied into the cts. i just read one of these on another forum. look to see if the ects, temp sensor, (the 2 wire one) is plugged in, his was not. it is located on the cross over pipe under the intake manifold on the drivers side. either #1 or #4 in pic, the 2 wire unit. also look for bad wiring. http://i249.photobucket.com/albums/gg240/johnceggleston/366494903601.png http://i249.photobucket.com/albums/gg240/johnceggleston/wt5056-1.jpg Link to comment Share on other sites More sharing options...
