alyolles Posted December 20, 2014 Share Posted December 20, 2014 Hello all, I've had this grinding that seems to be coming from the front passenger side since i bought the car 4 months ago but it has progressively gotten worse. It only does it under acceleration at very low speeds and when its very cold. Does anybody know what this could be? 2005 5EAT SPT exhaust, VF-52 turbo and intake done. Here is the link to the video of the noise Thanks in advance Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 20, 2014 Share Posted December 20, 2014 Check your CV? Heat shield? Link to comment Share on other sites More sharing options...
alyolles Posted December 20, 2014 Author Share Posted December 20, 2014 The heat shield had a whole in it about three inches in diameter about three months ago, could that be it? How exactly would i check the CV? Link to comment Share on other sites More sharing options...
alyolles Posted December 20, 2014 Author Share Posted December 20, 2014 Dont think its a CV, doesnt necessarily do it when turning Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 20, 2014 Share Posted December 20, 2014 I couldn't really hear the noise all that well on your video- could be my issue- but typically low speed popping/grinding noise would be CV- and passenger side one is most notorious due to how close it is to the downpipe (hot/cold cycles wears out the rubber). Inspect your CV boot for tears/leaks- if it's already popping you will more than likely need to replace. Heat shield will more than likely still make noise when in idle- might not until under load, but might be worth the effort to see if you can hear it under the hood while parked with slight revs (no more than about 2500 rpms, maybe up to 3k). This will let you see if you can track it down under the hood. Is there a modified downpipe with your new turbo? Are you custom tuned for that turbo? Link to comment Share on other sites More sharing options...
alyolles Posted December 20, 2014 Author Share Posted December 20, 2014 Cant here it while not moving, Perrin downpipe and Cobb Accessport Link to comment Share on other sites More sharing options...
alyolles Posted December 20, 2014 Author Share Posted December 20, 2014 If it is a CV, why does it only do it when its cold? Link to comment Share on other sites More sharing options...
MrTris Posted December 20, 2014 Share Posted December 20, 2014 Wheel bearing. Mine makes a similar noise around 50-60, intermittently, then smooths out again around 70+ Link to comment Share on other sites More sharing options...
alyolles Posted December 20, 2014 Author Share Posted December 20, 2014 If its a bearing why does it only do it when cold? Link to comment Share on other sites More sharing options...
MrTris Posted December 20, 2014 Share Posted December 20, 2014 Grease is cold, compacted, and isn't lubricating the bearing, so it howls. Once the car starts moving and generates enough friction to liquefy the grease, it quiets down. Link to comment Share on other sites More sharing options...
alyolles Posted December 20, 2014 Author Share Posted December 20, 2014 Is there anyway to prevent that issue with the grease, as in, does that mean something needs to be fixed/changed? Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 20, 2014 Share Posted December 20, 2014 Means you need to get a new wheel bearing- the current bearings have worn away enough to cause a large gap- when cold, the grease has not expanded enough to fill the gap, causing noise. When you have driven enough to heat up the wheel bearings, the grease expands enough fill the gaps. Only fix is replacement- which is another common issue with these cars. Link to comment Share on other sites More sharing options...
alyolles Posted December 20, 2014 Author Share Posted December 20, 2014 How would I know how bad it is or how long I can wait to replace it? Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 21, 2014 Share Posted December 21, 2014 Usually the noise means it's bad- period. Some people go quite awhile on bad bearings, but the longer you go, the more likely damage to the hub assembly- increasing your chances of needing to replace the hub assembly as well as the bearing. Check the Walkthrough section here: http://legacygt.com/forums/showthread.php/front-wheel-bearing-diy-walkthrough-86994.html Link to comment Share on other sites More sharing options...
MrTris Posted December 22, 2014 Share Posted December 22, 2014 Long story short as far as consequences go- the wheel bearing can and will seize over time; at high temperature, such as from freeway speeds, wheel bearings have been known to weld themselves to the hub. I'll leave you to your imagination as to what can happen at high speed when that eventually takes place. These cars eat wheel bearings, that's the cold hard fact.There are many threads about what to use to replace them, see the IDEA sticky. What happened with the cooling problem? Did you get the head gasket repaired, or is it still band-aided along? Wheel bearings, head gasket. . . have you resigned yourselves to the fact that this is not an ideal ride for a college student with no real budget for car maintenance and repairs? (Not including insurance, expensive gas, etc..) At the rate you're going, it's either going to be practically brand new by the time it gets passed down to you, or, it'll be dead in the driveway, gathering moss and rusting away.. Link to comment Share on other sites More sharing options...
starionesir Posted December 22, 2014 Share Posted December 22, 2014 Have you turned the car back and forth while driving in say a parking lot? Reason I ask is that is how you can determine if and which bearing is bad. When you turn side to side while driving slowly you will load and unload weight onto the bearings which will tell you which side is the bad bearing. When the weight of the car transfers on the bad bearing it will howl loudly and when unloaded it will quiet down. Link to comment Share on other sites More sharing options...
alyolles Posted December 23, 2014 Author Share Posted December 23, 2014 New head gaskets, new short block, rear wheel bearing going as well as front control arms, and front left sway bar. Also needs new front rims because the ones on there right now are deformed (slightly square) from potholes and hard driving I'd assume. Once new rims are on the other problems won't need to be dealt with for some time. Fun. Link to comment Share on other sites More sharing options...
