ynot kustoms Posted December 10, 2014 Share Posted December 10, 2014 so ive had a lot of bad crap happen with my lego wagon 3rd trans was great got from a kid who went 5spd had a shift kit in it but went on a trip for 3 hours straight and almost to wifeys aunts kid in the back and BOOM and no 4th/3rd whatever it is and no reverse found that after pulling in to a gas station and couldn't back up only luck was a friend with a trailer was just happen to be coming to the area the next day and more crap it barely fit on it had to go over the wheel hump so my hitch chain holder snapped had to jump through window and pulled the ebrake before it hit a power pole so anyways more bad had my dad help get another trans he found one in a junk yard they said was great well got it in and went to fix oil leaks and coolant and had a cam slip took a huge chunk outa my finger and well got some good heads(gigity) and started to put them on to find my torque wrench was bad and stripped the block hole so ya great times got some money from grandma passing so I got a jdm motor and its great just to find my trans slips horribly 1st to 2nd and had a torque bind on turns so I took the rear off the old trans and swapped it out the torque bind is gone but the slip is just horrible still and went to a buddys and it slipped in park on a slight hill but cant find the info on whats going on I saw it somewhere but no luck finding it any help would be great and yes the at temp light flashes 16 times and havnt gone into the codes yet having a lil gremlin(kid almost 2)monster) takes a lot of my time helppppppppppppppppp. I just want to swap to 5spd but no funds for that yet so somehow gotta figure a way to fixish this one have parts from other trans Link to comment Share on other sites More sharing options...
johnegg Posted December 11, 2014 Share Posted December 11, 2014 so ive had a lot of bad crap happen with my lego wagon 3rd trans was great got from a kid who went 5spd had a shift kit in it but went on a trip for 3 hours straight and almost to wifeys aunts kid in the back and BOOM and no 4th/3rd whatever it is and no reverse found that after pulling in to a gas station and couldn't back up only luck was a friend with a trailer was just happen to be coming to the area the next day and more crap it barely fit on it had to go over the wheel hump so my hitch chain holder snapped had to jump through window and pulled the ebrake before it hit a power pole so anyways more bad had my dad help get another trans he found one in a junk yard they said was great well got it in and went to fix oil leaks and coolant and had a cam slip took a huge chunk outa my finger and well got some good heads(gigity) and started to put them on to find my torque wrench was bad and stripped the block hole so ya great times got some money from grandma passing so I got a jdm motor and its great just to find my trans slips horribly 1st to 2nd and had a torque bind on turns so I took the rear off the old trans and swapped it out the torque bind is gone but the slip is just horrible still and went to a buddys and it slipped in park on a slight hill but cant find the info on whats going on I saw it somewhere but no luck finding it any help would be great and yes the at temp light flashes 16 times and havnt gone into the codes yet having a lil gremlin(kid almost 2)monster) takes a lot of my time helppppppppppppppppp. I just want to swap to 5spd but no funds for that yet so somehow gotta figure a way to fixish this one have parts from other trans so I took the rear off the old trans and swapped it out the torque bind is gone but the slip is just horrible still and went to a buddys and it slipped in park on a slight hill but cant find the info on whats going on THE PARKING ''PAWL'' IS MESSED UP. THIS IS A COMMON ERROR WHEN REMOVING THE REAR SECTION OF THE AUTO TRANS. (sorry for the caps.) but i think your ATF level is low. and the damage may be permanent. if you have installed 3 auto trans and all 3 have had problems, you are doing something wrong. the at temp light flashes 16 times and havnt gone into the codes yet this will tell you what is wrong with the electronics in your trans. sooner is better than later. PS: HOW ABOUT USING SOME PUNCTUATION, PLEASE? Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 11, 2014 Author Share Posted December 11, 2014 :jedi:im writing on a mini lab top so bare with me. thanks for reply. I know how to change a trans out. when I got the car the trans was bad slipping like it is now but the last one was awesome:cool: but the prob with it was the pan was glued on with some crazy stuff that I couldn't get the off with out bending and scratching the hell outa the trans so I put an external filter and ran great till the 3 hours straight then boom felt like getting hit by something. so now this one. :confused:I don't see how I messed up when I swaped the rear it was just pull off and put on essentially and after I did it the turning torque bind was gone and just slips hard 1st to 2nd. :spin:I have parts from old trans any way I can look through it and find good parts and make a good one. :bbq:I think the old trans only had the issue with the 4th and reverse clutches? Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 12, 2014 Author Share Posted December 12, 2014 ok well today driving it was shuttering shifting hard at slow speeds unless I step on it then itll shift just fine Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 12, 2014 Author Share Posted December 12, 2014 so the pawl is the shifter selector? if that's what your talkn about, I had my dad help me out alil so not sure if that got moved or what. ive been working on cars since 16 but new to subarus Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 12, 2014 Author Share Posted December 12, 2014 Link to comment Share on other sites More sharing options...
johnegg Posted December 12, 2014 Share Posted December 12, 2014 the parking pawl is the catch that locks on a cog to keep the gears from turning, it is what makes ''park'' work. there is a spring in the rear extension housing that keeps the pawl in place. if the spring is dislodged the pawl will nor engage, no park. google, subaru parking pawl. Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 12, 2014 Share Posted December 12, 2014 I had trouble with the pawl engaging on my 4eat when I messed with the neutral safety switch so perhaps it needs some adjustment as well. Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 13, 2014 Author Share Posted December 13, 2014 it goes into park normally but on a slight hill it was slipping back. adjust the selector or you sayin I gotta take the back piece off again and check the spring. im losing my mind chasing demons on this car I love it but damn shoulda never let the wife decide manual or auto cuz to find out later that she could drive stick since she works for xbox and they have the simulator that shes well versed in soooooooo ya as soon as I can no more auto im gonna hopefully take a look at it this weekend thanks both of ya Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 13, 2014 Author Share Posted December 13, 2014 and can someone take a pic of a trans stick next to a oil stick my dumbass left it under the hood and lost it but had an extra oil stick trimmed it alil and seems to be where it shoulda been. I know somewhere in my mess of a garage(destroyed since the start of this non stop crap) I have an extra stick but yet to find it Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 13, 2014 Share Posted December 13, 2014 The neutral safety switch is held in by three slotted screws. Loosen them and shift through the gears a few times and tighten it back up. It's possibly to adjust the switch with a spanner wrench as well but I didn't have any luck with that so ymmmv. Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 14, 2014 Author Share Posted December 14, 2014 ok so I played with the safety switch and it seems to drive a lot better but didn't drive far since ive been drinken again:cool: but also put in some really nice green hoeses ;p and had to trim alil header wrap back since I leaked trans fluid on it and it just kept smoking wifey kept complaining(her moms vanagon caught fire when she was a kid) Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 15, 2014 Author Share Posted December 15, 2014 okay so drove longer today and was great till it was warmed up and started acting up again but not as bad. im gonna try to find the procedure to adjust it somehow.... Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 15, 2014 Share Posted December 15, 2014 I found this diagram. Maybe it will help. It's from a later model but it looks to be the same. I don't remember messing with the stopper pin and maybe that's why mine is still out of adjustment. My SS has a turbo so the downpipe is in the way of the switch so I have to pull it to adjust it again. Also I found this text (there are no diagrams with it) again: "Some 2005-08 Legacy, Outback, Impreza and Forester models with the 4EAT automatic transmission may turn on the MIL and store DTC P0851 and/or P0852 in computer memory. One likely cause for the code(s), reports Subaru, is a misadjusted inhibitor (Neutral safety) switch and gearshift cable. Adjusting both components should turn off the light in a hurry. Here’s the drill: Start by placing the gearshift lever in Neutral. Now loosen the three inhibitor switch attaching bolts. Using the left-hand illustration on this page as a guide, insert a stopper pin or brass drift into the holes in both the switch lever and body, as shown. Keeping the pin as straight as possible, tighten the switch attaching bolts to 30 in.-lbs. Now move on to the gearshift cable adjustment. Using the illustration on the right for reference, loosen adjusting nuts A and B of the cable. Now tighten adjusting nut B until it just makes contact with the connector lever. Using a spanner wrench or similar tool to prevent nut B from rotating, torque adjusting nut A to 65 in.-lbs. The cable is now properly adjusted. To complete the fix, check that the shift detents engage each gear smoothly, the starter turns in Park, the backup lights work in Reverse and the Park lock engages when the shift lever is placed in Park." Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 16, 2014 Author Share Posted December 16, 2014 thanks so much monkey hopefully get to this 2mro if I don't work(ie doin wifes job play video games its a hard job but somebody has to do it Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 20, 2014 Author Share Posted December 20, 2014 I did it and does shift better. I used a 5/32 roll pin and crammed it in and got it leveled and definitely do it with something in the holes ; p I really wanna rebuild my old trans. Anyone got the rebuild guide they wanna post up Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 20, 2014 Author Share Posted December 20, 2014 Oh and when I did the rear part to check it once in park I just pulled off the pin on the inhibitor switch and checked the cable to see how hard it was against itself Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 23, 2014 Author Share Posted December 23, 2014 still shifts hard 1 to 2nd and worse when warmed up and now getting a p0748 code I just wanna kill somebody for making me stuck with a damned automatic, my manual car had its issues sometimes but would still work even through one bad trans with seal leak just kept spraying brake cleaner once and awhile and kept going till I fixed it even when one bad gear could still power shift through it lol but this damn automatic keeps me up at night trying to figure it out, I have plenty of parts from the old trans.s I wanna fix/rebuild the old one with shift kit until I get money again then swapping that crap for 5mt fml ftw Link to comment Share on other sites More sharing options...
johnegg Posted December 23, 2014 Share Posted December 23, 2014 p0748 code shift solenoid A. either it is bad or it has a bad circuit. shift solenoid A probablt controls the 1-2 shift. Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 30, 2014 Author Share Posted December 30, 2014 okay so I changed out the whole valve body hoping to get my shift kit one in and fix my problems but instead. so now when I start to go it takes abit to go like its slipping till it catches but once going it seems great ill have a more test drive 2mro so hopefully itll feel better and not boom on start up it still flahes I just cant figure the secret handshake is there a plug ur suppose to put a wire in and ground it ive looked and cant find a straight answer Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 30, 2014 Author Share Posted December 30, 2014 ok looked alil and found some things about the trans codes being different and they are but how much different could it be im losing my mind I ripped the heart of the trans and put a pig heart and finally stitched it up it now it walks like a slug and runs once going Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 30, 2014 Author Share Posted December 30, 2014 the codes are pretty close tz102z2aaa-cg on the car and old is tz102z2dca-ke Link to comment Share on other sites More sharing options...
johnegg Posted December 30, 2014 Share Posted December 30, 2014 tz102z2aaa - 96? legacy LSi auto trans? tz102z2dca - 97/8 GT auto trans they are the same. Link to comment Share on other sites More sharing options...
ynot kustoms Posted December 31, 2014 Author Share Posted December 31, 2014 Mines a gt. Ya I figured there the same. Finally figured the secret handshake and found 4 sensors bad so gonna rip it apart again and hope my original trans solenoids are good Link to comment Share on other sites More sharing options...
