bochinam Posted December 10, 2014 Share Posted December 10, 2014 Typically, when I've had the work done in the past there has always been a reasonable amount of material removed. Best practice when installing a new clutch or overkill? Opinions? Link to comment Share on other sites More sharing options...
ras06LGT Posted December 10, 2014 Share Posted December 10, 2014 If the flywheel resurfacing is done correctly, I wouldn't imagine you'd need to have it re-balanced. I always thought you were supposed to change the friction disk and pressure plate as a pair. Is that not correct? Link to comment Share on other sites More sharing options...
bochinam Posted December 10, 2014 Author Share Posted December 10, 2014 Yes, new disk. However, only the PP and FW are balanced together. Link to comment Share on other sites More sharing options...
