Energyblue98 Posted December 6, 2014 Share Posted December 6, 2014 Let me preface this by saying that I have seen posts related to this topic, but none of them seemed to have a conclusive answer.. My airbag light has come on my 2008 Spec B. If i turn the car off and on again it will go away for a few seconds but then come right back. I don't want to screw around with this as I don't want (1) the airbag to deploy while driving or (2) the airbag to not deploy in an accident. Is this a common problem with a sensor somewhere? where can I start checking? or is this a computer reset problem? I have recently changed out the battery with an optima.. did something reset? Link to comment Share on other sites More sharing options...
Energyblue98 Posted December 8, 2014 Author Share Posted December 8, 2014 ... nothing? Link to comment Share on other sites More sharing options...
theflystyle Posted December 8, 2014 Share Posted December 8, 2014 http://lmgtfy.com/?q=airbag+light+site%3Alegacygt.com Link to comment Share on other sites More sharing options...
zstalker Posted December 16, 2014 Share Posted December 16, 2014 It's just like a check engine light...lots of codes and it's futile throwing parts and money around without knowing the code. Have a shop pull the code, then you'll have a starting point. Link to comment Share on other sites More sharing options...
Fabius Posted December 20, 2014 Share Posted December 20, 2014 I have the same light pop up. we scanned the car and it comes out as the "passenger air bag inflator". the light comes and goes depending if i have a passenger in my car or not. What is weird is that when a person is sitting in the car the light is on. The next time i am driving alone the light is gone till the next time i start the car again. I am not to sure if it is the inflator or the weight sensor in the seat. get it scnned. Link to comment Share on other sites More sharing options...
SamC Posted January 12, 2015 Share Posted January 12, 2015 I had this issue with my 09 Legacy. The only solution I could find is to remove the overhead console and re solder the connections. Trust me this actually works. Do a search for this fix and you will find plenty of instructions. Link to comment Share on other sites More sharing options...
Energyblue98 Posted January 13, 2015 Author Share Posted January 13, 2015 I had this issue with my 09 Legacy. The only solution I could find is to remove the overhead console and re solder the connections. Trust me this actually works. Do a search for this fix and you will find plenty of instructions. If you say this works then I will believe you and I will do it. but are you sure this would fix the airbag light on the dashboard? The passenger side weight sensor seems to be working fine and the overhead console indicator light seems to be working just fine. Link to comment Share on other sites More sharing options...
SamC Posted January 14, 2015 Share Posted January 14, 2015 This was the same issue I had. The overhead indicators seemed to be working fine. After I re soldered the connections the indicator lights where brighter and the dashboard light turned off. I haven't had any problem since. Link to comment Share on other sites More sharing options...
chasesavestheday Posted January 15, 2015 Share Posted January 15, 2015 Guys, take a look at this thread. I'm having the same issue with my 2009 and will be attempting this tomorrow. http://legacygt.com/forums/showthread.php/airbag-light-sometimes-console-problemi-149073p4.html?highlight=airbag+light Link to comment Share on other sites More sharing options...
