Jzook02 Posted December 3, 2014 Share Posted December 3, 2014 Lately, my driver side door has been giving me some problems. When you go to open it, it goes about an inch or so without problem, but then you have to pull a lot harder than normal to get it to budge. I could not see anything catching when opening the door. Any ideas? Link to comment Share on other sites More sharing options...
robinlsb Posted December 3, 2014 Share Posted December 3, 2014 Spray the crap out of it with WD40. That means outside into the area exposed with the handle up, the inside on the where ever you can get to it. near the latch. Don't worry about over spray. The Subie lock system can be a bear. If you don't go crazy with lube now, you may be stuck with a door that will not unlock. And that is a real PITA "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
MrTris Posted December 3, 2014 Share Posted December 3, 2014 I like this stuff, personally: http://www.fluid-film.com/ Link to comment Share on other sites More sharing options...
Jzook02 Posted December 11, 2014 Author Share Posted December 11, 2014 Thanks! Turns out my window was what seemed like suction cupping to the rubber liner. Odd but it works fine now. Link to comment Share on other sites More sharing options...
