90legacysw Posted November 29, 2014 Share Posted November 29, 2014 Hello hope someone has some insight on this problem I have a 1990 legacy sw 2.2 89000 origianl miles just bought it it had been sitting bought off original owner got it home cleaned it up drained gas oil put new fuel pump in got spark got juice to injectors cranks won't start use start fluid fires right up runs until it uses that any ideas Link to comment Share on other sites More sharing options...
90legacysw Posted November 29, 2014 Author Share Posted November 29, 2014 Hello again I do not do well with these forums hopefully I did it right how do you get rid of this singles advertisments Link to comment Share on other sites More sharing options...
snederhiser Posted November 29, 2014 Share Posted November 29, 2014 Hello; Is the new fuel pump working? Check to see if you have power back there. If not check the relays. Also check the under hood fuel filter. Pull the vacuum line off the fuel regulator and make sure there is no fuel leaking there. You can pull the return line off the main harness on the drivers side and see if fuel is present. Cannot think of much more, Steven. Link to comment Share on other sites More sharing options...
90legacysw Posted November 29, 2014 Author Share Posted November 29, 2014 Thanks yes fuel pump works great fuel filter new regulator good have spark checking injectors ohms think that's the problem three no ohm reading Link to comment Share on other sites More sharing options...
snederhiser Posted November 30, 2014 Share Posted November 30, 2014 Hello; Hook up a test light across each injector plug to make sure that you are getting a signal to each injector. You should be getting an ohm meter reading of 10-15 across each injector. If you are not getting a signal check the cam/crank sensors, wiring, or a faulty ecu. No ohm reading or open circuit would indicate faulty injectors, Steven. Link to comment Share on other sites More sharing options...
90legacysw Posted December 1, 2014 Author Share Posted December 1, 2014 Thanks for the help can you tell me how to get out off of this forum site just want to unsubscribe to this site Link to comment Share on other sites More sharing options...
GTEASER Posted December 1, 2014 Share Posted December 1, 2014 Thanks for the help can you tell me how to get out off of this forum site just want to unsubscribe to this site Why? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Stapp's Law: “The universal aptitude for ineptitude makes any human accomplishment an incredible miracle.” "Simple incompetence is a far more sinister force in the world than evil intent." Link to comment Share on other sites More sharing options...
90legacysw Posted December 2, 2014 Author Share Posted December 2, 2014 Want to unsubscribe to this forum because I do not like being on these things not sure why I singed up got the problem fixed so can you tell me how to get off here I have email to find out I do not know how to unsubscribe thanks and hope you will understand what are the steps to unsubscribe please Link to comment Share on other sites More sharing options...
