gxp05 Posted November 26, 2014 Share Posted November 26, 2014 hey I got a 1999 Sudbury Brighton I got a leak coming from under the dash on the passenger side the windshield is not leaking I got it check at a window shop the leak is coming somewhere from the heater box im hoping someone can help me out thanks Link to comment Share on other sites More sharing options...
GTEASER Posted November 26, 2014 Share Posted November 26, 2014 Sounds like the heater core is leaking as a result of a crack or rusted out. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
gxp05 Posted November 26, 2014 Author Share Posted November 26, 2014 where would the water be coming from? I put a garden hose on the windshield for like 2 hours no leak... get a huge rain storm it mite leak but more then likely it doesn't.... it leaks only when it wants too its soo weird Link to comment Share on other sites More sharing options...
GTEASER Posted November 26, 2014 Share Posted November 26, 2014 Engine coolant runs through the heater core which is located in the interior of the car, behind the dashboard. If it's leaking, it will leak down into the front footwell area. Do you have a sunroof? Sometimes the sunroof drains which run thru the A-Pillar clog up with leaf debris and dust, and essentially the roof floods under the headliner and the water can run down the A-pillar trim into the footwells. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
johnegg Posted November 26, 2014 Share Posted November 26, 2014 does the car have a sun roof? i can't imagine a brighton would have one but who knows. heater cores can go bad, but usually you would smell the ''sweet smell'' of anti-freeze. AC condensation drain is much more common. try not using the AC or the defrost for several days and see if it leaks then. the drain tube goes from inside the car , through the fire wall on the passenger side of the engine compartment, and then down so it will drip on the ground. if it is plugged it could leak into the car. Link to comment Share on other sites More sharing options...
gxp05 Posted November 26, 2014 Author Share Posted November 26, 2014 no sunroof.. its only leaks sometimes when it rains... and it leaks water sorry I wasn't clear that it leaks water Link to comment Share on other sites More sharing options...
GTEASER Posted November 26, 2014 Share Posted November 26, 2014 Good call johnegg, didn't think about the AC drain. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
gxp05 Posted November 26, 2014 Author Share Posted November 26, 2014 its not the ac condenser drain it leaks when the cars sits over night Link to comment Share on other sites More sharing options...
