efancki Posted November 23, 2014 Share Posted November 23, 2014 Is there a fuse on the back of the stock radio? my stereo is not keeping it's preset stations and time. I have looked in the fuse box and no fuses are out. I am just tired of having to set a station every time I get in or out of the car. Link to comment Share on other sites More sharing options...
johnegg Posted November 23, 2014 Share Posted November 23, 2014 the installer wired it wrong. one of the wires in the harness is a ''always hot'' feed. it is supposed to be connected to the ''memory'' wire on the radio. obviously the ''memory'' wire is connected to a wire switched by the ignition. BE REALLY CAREFUL if you go in and correct this. it is easy to blow the ''iluminator'' relay that feeds the dash lights. i would get the correct wiring diagrams for the radio and the car harness, and then disconnect the battery to do the work. Link to comment Share on other sites More sharing options...
efancki Posted November 23, 2014 Author Share Posted November 23, 2014 Ok thanks for the info. I am probably just going to deal with it until i can buy a new head unit. I pulled the radio out this morning just to see if there was a fuse in the back and didn't see one. I did change out my shifter light while i had the center console apart. So at least i got something done today. Link to comment Share on other sites More sharing options...
