Nexto Posted November 22, 2014 Share Posted November 22, 2014 Hey, so im new to subarus but not new to wrenching. I recently bought a 98 wagon 2.5 that needed a clutch installed. The car came with a luk clutch from rockauto.com. After installing it the throw out bearing started to make a squealing noise like a belt with the clutch fully engaged (pedal out) thinking it was a bad bearing i got one from subaru and replaced that. Still same problem. At the point im thinking that the pressure plate is not quite the right size or there is some thing defective with it. So my question is, what clutches have you guys used, where did you get them, how much and are you happy with it Thanks. Link to comment Share on other sites More sharing options...
