brelandt Posted November 22, 2014 Share Posted November 22, 2014 New to the forum! Just bought my very first Subaru. Got hooked on the MCM gramps build and had to have a Legacy....LOL Anyhow, I bought a '98 Legacy GT Wagon with a 5 speed in black. I had been looking for a Subaru on Craigslist here in the Bay Area for a few weeks and had not seen another one. Cars got 177K and runs great. Appears to have been well maintained. I am a mechanic but I am mostly the "alignment" guy and don't get much time changing timing belts and the sorts. The P/S pump has a leak and it looks like the valve cover and oil pan may be leaking as well. Seems easy enough to fix. Great info on these cars here. Been using the hell out of the "search" button! Link to comment Share on other sites More sharing options...
PingPong Posted November 22, 2014 Share Posted November 22, 2014 The quirkiness of Subaru wears out fast after you start working on them:rolleyes: Change out the spark plugs and wires while you do the valve cover gaskets. You'll be taking out more than half of what makes up the engine bay out to get to them. You'll have to lift the engine to be able to change out the oil pan gasket and make sure you have a good selection of wobble extensions! Welcome and good luck. Link to comment Share on other sites More sharing options...
zangado1 Posted November 22, 2014 Share Posted November 22, 2014 The quirkiness of Subaru wears out fast after you start working on them:rolleyes: Change out the spark plugs and wires while you do the valve cover gaskets. You'll be taking out more than half of what makes up the engine bay out to get to them. You'll have to lift the engine to be able to change out the oil pan gasket and make sure you have a good selection of wobble extensions! Welcome and good luck. Really? I had no idea to change the oil pan gasket that you had to lift the motor. Is that the only way or is there a tougher way to change it out without lifting it? I just bought a Fel-Pro for my 2.2. Link to comment Share on other sites More sharing options...
brelandt Posted November 22, 2014 Author Share Posted November 22, 2014 I watched brianmobile1 change one on his youtube channel. He lifted the motor about 1" and removed the oil filter and loosened the oil cooler. Looked easy enough. I might just go with Toyota gray sealant instead of a gasket. Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 24, 2014 Share Posted November 24, 2014 The Factory Service Manual calls for Fujibond sealant for the oil pan gasket, not a cork gasket like the FelPro. I used Permatex Ultra Gray. Oil pan leaks are fairly rare, usually it is sludge from another oil leak that makes it look like the pan is leaking. Link to comment Share on other sites More sharing options...
