BoxerLove Posted November 20, 2014 Share Posted November 20, 2014 Is it possible to add a remote start to the factory 98 legacy gt with factory Subaru alarm? Link to comment Share on other sites More sharing options...
corlon Posted November 25, 2014 Share Posted November 25, 2014 yes Link to comment Share on other sites More sharing options...
BoxerLove Posted November 26, 2014 Author Share Posted November 26, 2014 yes Without removing the stock system? A little more info would be nice. Link to comment Share on other sites More sharing options...
lockmedic Posted November 26, 2014 Share Posted November 26, 2014 Probably best to have this conversation with your local autosound/security installer. Yes, it's possible without removing the factory system, although I can't fathom why you'd want to keep that dinosaur. It's not a true "factory designed, factory installed" system. . . it's an aftermarket box made by Code Alarm and sort of shoved up under the dash and held in with wire ties and tape. Current production aftermarket systems have better range, more features (trunk release, perhaps?), and generally work better. Link to comment Share on other sites More sharing options...
twisty Posted November 26, 2014 Share Posted November 26, 2014 if it is an alarm with remote start, you could disable the oem security and use the alarm security. if it is a separate remote start only, you can add it to the car with or without the oem security, and integrate it (or bypass) with any start kill the alarm is doing. if you want a longer, more in-depth answer youll have to give some more detail on your plans. Link to comment Share on other sites More sharing options...
