Condor Posted November 3, 2014 Share Posted November 3, 2014 about a month ago i put in my catless up pipe and finally got rid of the remaining scraps of plastic that was the stock engine tray. now that winter is approaching, id like to get it covered up again. while doing the up pipe i took the heat shields off while dropping the headers and they were not salvageable, completely rusted and falling apart. so im looking for recommendations. do i get a new stock plastic tray? do i get an aftermarket aluminum/steel skid? i go down some dirt/gravel roads for work, nothing to bad, some small roots and rocks (never bottomed out). also is it worth getting the stock heat shields again or should i just wrap them in something to hold the heat in better. thanks a lot! Link to comment Share on other sites More sharing options...
chato Posted November 4, 2014 Share Posted November 4, 2014 if you're handy you could probably make one pretty easy out of aluminum sheet, in fact I seem to remember a thread where someone posted dimensions for that. I have a primitive racing unit. its a great skid plate, but I don't love the mounting system. there's a couple more brands out there, but they are starting to get scarce. the car is designed to have that plate underneath for both protection and intercooler/radiator airflow. I wouldn't wrap the headers, that'll just make them rust more quickly. Link to comment Share on other sites More sharing options...
hakkalugi Posted November 4, 2014 Share Posted November 4, 2014 I have a friend with an older outback that made a nice skid plate out of an old road sign that had been sitting in the shop for a while. Me & my other buddy are going to make some out of similar material soon. Link to comment Share on other sites More sharing options...
Condor Posted November 4, 2014 Author Share Posted November 4, 2014 ive toyed with the idea of making one for awhile and just have never really made the commitment to it i guess. i did try using an old "trail closed" ski sign, but it wasnt quite the right fit Link to comment Share on other sites More sharing options...
InTheBay Posted November 4, 2014 Share Posted November 4, 2014 I tried the sign method the other day. I screwed a 2x4 to my work bench, and slid the sign under it in order to make some bends for the rad offset mounts. I slid it under, then used a C-clamp on the other side. I started leaning into it to make the bend, then my screw pulled loose out of the left side of the 2x4. The 2x4 pivoted and smoked me right in the face, right on my orbital bone and nose. Hurt like a motherfucker. I'll be buying a primitive plate. Link to comment Share on other sites More sharing options...
chato Posted November 4, 2014 Share Posted November 4, 2014 found the thread: http://legacygt.com/forums/showthread.php/diy-skidplate-197388.html?t=197388 Link to comment Share on other sites More sharing options...
Condor Posted November 10, 2014 Author Share Posted November 10, 2014 Awesome! Thanks. Might give this a shot tomorrow. Link to comment Share on other sites More sharing options...
turboboost Posted November 10, 2014 Share Posted November 10, 2014 Big fan of the Primitive skid plate. Got the 3/16" with no cutouts. Only wish that they had coverage extended to the fog light area. Overall, very heavy duty and well-constructed piece. Link to comment Share on other sites More sharing options...
